Racing The place to talk about autocrossing, road and drag racing.
TO OR NOT TO USE <<e-85
Old Jan 13, 2019 | 06:04 PM
Default Re: TO OR NOT TO USE <<e-85
Gas with ethanol has a shorter shelf life so you have to add Stabil or equivalent when storing your car. Ethanol does cause damage to your car no matter what they say and gas wth ethanol gets poorer gas mileage, dries out rubber, any water in it causes corrosion, if you had any water in your gas tank it will get absorbed by the ethanol.
I prefer my ethanol in single malts, beer or whatever.
^THAT^ Right there. Period.
Old Jan 26, 2019 | 01:17 PM
DragonSlayer129!'s Avatar
I am waiting for warmer weather and clear roads I will then data log 91 octane in the V8 vs 33% E-85/91 octane and post results. After I chatted with Jim the other night I did some research as well and lots of folks are doing this and I can't find a reason not to try it.
Old Jan 26, 2019 | 01:35 PM
AtomicBubbles's Avatar
i will note that the other day I filled with the usual 3 gallons of e85 and 7 of 91 and after about 10 minuets of casual driving got a CEL for “System too lean” for both banks 1 and 2. I filled the rest up with 91 to even out the mixture. Reset the CEL and it didn’t come back.
Unsure if that hat is actually a problem or if the computer is seeing it lean because it’s expecting regular gasoline to be used.
any thoughts on this would be great!
Old Jan 28, 2019 | 03:39 PM
I don't understand what was going on because our engine requires high test being we in Florida have 93 ,and this is what i am using with the 3 gal of E 85,,, you used 91 octane and got a eng light doesn't make sense,,,,. just driving around easy maybe try 1 gal,,,, then try 2 ga,,,,l then back to 3 gal ! by adding the extra 91 , did you feel any change with power??
Old Jan 28, 2019 | 06:20 PM
Does the gas he is using have some ethanol in it to start with? Some premium gas has it in and others not.
Old Jan 28, 2019 | 09:00 PM
don't know he has in his gas but.
all stations in Fl have a notice of ( up to 10% ethanol) some stations also have pumps that say NO ethanol.
the no ethanol price is about 50% more than the regular, but the octane is up,, Oh! E85 (85% ethanol) is 108 octane.
3 gal of e85 +7 gal 93 =97.5 octane or maybe 98.1,,,,counting the 10%
3 gal of e85 + 7 gal of 91 = 96.1,,, or maybe 96.5 counting the 10%
3gal of e85 + 7 gal 89 =94.7 or maybe 95 counting the 10%
maybe you can do your own math and put in the octane you want.
PS found out they reduce the octane in all gas and then add the 10% ethanol to bring it back up
Old Jan 28, 2019 | 10:08 PM
The more ethanol you have in your Crossfire engine the less MPG you get, the octane rating may be higher but that is of little use when the compression ratio is fixed.
If you wanted to save money on gas costs you should have purchased a smaller car with a smaller engine. Maybe you would be better of on the Prius forum. 😜 Surely the highest MPG can be got using 100% gasoline.
The more ethanol in the fuel the more damage can be done to components not designed for high ethanol blends.
What ratio of ethanol to gas is the most efficient for our cars? I for one prefer no ethanol, burning a fuel lower in latent power seems a waste of time to me.
Ethanol use is good for farmers income and bad for countries where corn is a staple in their diet, due to the higher prices.
Old Jan 29, 2019 | 08:29 AM
100 some times you just don't get it. some of us want power and don't give a (100) about gas mileage,, do your self a favor and drop off this thd. , in fact go to the Volkswagen forum you will fit in perfectly.
Old Jan 29, 2019 | 10:31 AM
You like to hear your own voice too much, and get annoyed at other people’s opinions if they do not coincide with yours. To get the best out of the higher ethanol mixes you need to upgrade the fuel system the boost and get a suitable tune, a higher compression ratio would help. With NA engines a higher compression ratio is required to obtain benefits.
Some of what you say is misleading and could cause engine damage, you are not always right no matter what you think.
My previous post which you got mad at is based on facts not some wishful sense of power felt through the seat of your pants.
Ethanol contains less power than gas, sure the octane rating is higher but that means squat.
Give us the facts and nothing but the facts.
Old Jan 29, 2019 | 05:03 PM
[QUOTE=onehundred80;918283]
You like to hear your own voice too much, LOL,,, the end
Old Jan 29, 2019 | 05:53 PM
[QUOTE=amx1397;918309]
It seems when you are faced with facts you would rather start insulting someone than offer plausible rebuttals, you sound like someone in power somewhere south of us up here.
You may know more than the average bear but I can’t see it here. How can you get more power out of something with less latent power in it?
You seem to equate more power from higher octane ratings.
Old Jan 30, 2019 | 03:19 PM
[QUOTE=onehundred80;918310]
100 again U R wrong my facts speak for themselves
E15 (15% ethanol, 85% gasoline) is a higher octane fuel available in 29 states at retail fueling stations. E15 was approved for use in model year 2001 and newer cars, light-duty trucks, medium-duty passenger vehicles (SUVs), and all flex-fuel vehicles (FFVs) by the U.S. Environmental Protection Agency (EPA) in 2012.
in 2018 Nebraska and some states close to it are, along with the fed gov. trying to get E 15 into all gas powered vehicles in their states,, supported by EPA and other gov. divisions
also E33 is being studied in 15 states for the 2001 and newer vehicles. the study just started in Jan 2019 so no answers there yet, but my test so far have shown positive results
Old Jan 30, 2019 | 04:33 PM
[QUOTE=amx1397;918353]
I am amazed that you can put all this twaddle out and believe it is a rebuttal of all I have said. What you state is quite true but as I have said before octane has nothing to do with the power potential in a fuel.
Old May 25, 2019 | 10:42 AM
after using 1/3 E85 for 3 months , added to my fuel in two cars a 2002 mercedes c320 ( same engine as a limited crossfire and a 2016 ford fusion 2.0 turbo yes it gives you a little more power but it decreases your miles per gal. I do not recommend adding 1/3 E85 for everyday use,,,,,,,(unless your car is a flex fuel and you want more power).... I looked at the fuel injectors and pump and hoses all look good.. I will use it when i go to the track as a power booster
i will report back after i try it at the track jim
satellite
Sep 28, 2010 01:52 PM
PA/XFIRE
19
Feb 22, 2010 08:15 PM
PA/XFIRE
Nov 9, 2008 09:11 AM
mrprated
Mar 15, 2008 04:21 AM
