Old Jan 29, 2019 | 10:31 AM
onehundred80
Default Re: TO OR NOT TO USE <<e-85
Originally Posted by amx1397
100 some times you just don't get it. some of us want power and don't give a (100) about gas mileage,, do your self a favor and drop off this thd. , in fact go to the Volkswagen forum you will fit in perfectly.
You like to hear your own voice too much, and get annoyed at other people’s opinions if they do not coincide with yours. To get the best out of the higher ethanol mixes you need to upgrade the fuel system the boost and get a suitable tune, a higher compression ratio would help. With NA engines a higher compression ratio is required to obtain benefits.
Some of what you say is misleading and could cause engine damage, you are not always right no matter what you think.
My previous post which you got mad at is based on facts not some wishful sense of power felt through the seat of your pants.
Ethanol contains less power than gas, sure the octane rating is higher but that means squat.
Give us the facts and nothing but the facts.
