Old Feb 2, 2019 | 12:07 PM
  #209 (permalink)
DHS's Avatar
DHS
Default Re: C32 Brake upgrade
Got the 50mm bolts for the front, they go all the way through the hub with the 5mm spacer. My spacer is not hub-centric and I drove it today. I have a little shimmy at 60 to 80, not sure if it is because of not having the hubcentric spacer. I did look around for the thinnest hub-centric spacer and found a 10mm one and got 55mm lugs. Looking at the current 50mm with the 5mm spacer I can see about 3mm of bolt on the inside of the hub. So I know I have a shimmy with this set up, l guess I need to switch to the hub-centric and see if the shimmy changes.
As for braking, after two bleeding’s the brakes are firm and seem to work well; also this should be very fade resistant. I also have the rears done and will show that on a new thread.
