Old Feb 4, 2019 | 12:31 PM
Xenial's Avatar
Xenial
Default Re: Took Xfire in and...
Originally Posted by amx1397
How many miles on the car? is this a limited or srt 6? I have my cats that came off my srt6 at 30000 miles but will sell in pairs,, both rear's or both fronts. $300 for either fronts or rear or $500 for all 4 ,,+ shipping. now for my thinking,,change your oil use moble 1 0-40 maybe the ticking, they all tick but not too loud.
do you have an engine light on if yes what code?
I really believe your 02's are ok and throttle body is ok too if it is a srt then you most likely need a supercharger pump
also do the throttle reset. (search throttle reset.) dis connect batt. for 2 to 4 min this will reset most everything. tell us also in the 6 months did u have any problems? jim
Q - How many miles on the car?
A - I purchased the vehicle at 118k miles, when i left at the dealer i was at 127k miles
Q - Limited or SRT?
A - Limited
I had the oil changed recently before these issues occured, the ticking and excuse me, its was a knocking and tick, that i could feel in the car as i drive. And it would get louder and more abrupt as i accelerated.
Q - Was the engine light on? And What Codes?
A - The Check Engine light was on these are the codes i was told the car diagnosage received.
  1. P0152 O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
  2. P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
  3. P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
  4. P0137 O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
  5. P0123 Throttle/Petal Position Sensor/Switch A Circuit High Input
  6. P0410 Secondary Air Injection System Malfunction
Q - Any issues in the six months i've had the vehicle?
A - As far as i can tell, just the Crankshaft Position Sensors, which triggered the code in the car, i purchased two of them, however i have not had them put in yet.
My car is currently at the dealer's service center, so doing a throttle body reset will have to wait until i arrive at the dealer sometime this week.
