Old Feb 4, 2019 | 03:19 PM
Xenial's Avatar
Xenial
Default Re: Took Xfire in and...
Originally Posted by amx1397
I would be surprised if the dealer used Mobil 1 0-40 as it cost around 9.00 per qt ($25.00 for 5 qts at walmart ,,the crossfire takes just under 9 qts.
all those codes happen when you have low batt, clear them all and start over (dis connect batt for 5 min. open and close door 5 or 6 times to discharge all components can you record the knocking. does the ticking and or the knocking happen at idle? here is the throttle reset
https://www.crossfireforum.org/forum...throttle+reset
I will try all these when I pick up my Crossfire later this week. The knocking and ticking is happens even at idle, and when I'm driving it get louder, the car has trouble accelerating and it gets louder just trying to get to highway and road speeds, I can feel the loss of power too, so I know something is definitely wrong. I will do a throttle reset as you and the others have mentioned once I pick it up later this week. Also I will record the sound. Most likely will pick it up this Friday, so please stay tuned.
