Old Feb 7, 2019 | 10:03 AM
onehundred80
Default Re: Spring damper on clutch pedal
Originally Posted by DaveLad
Hi!
Thanks for your input.....yeah, I was shocked ! when it dropped off into the footwell thinking that the clutch might not work properly....but as it has nothing to do with the actuation of the clutch mechanism and it seems to be there purely to create a smooth pedal action (iron out the hydraulic resistance when depressing the pedal), I'll see how it goes...
Also, the broken anchor point is so high up behind the dashboard that welding it back on would be, I imagine, a massive job and costly....
If things change I'll post an update.....cheers for now.
Does the spring keep the pedal up and away from having the pressure pad resting on the clutch actuator. If so it would be like driving with your foot pushing on the clutch all the time.
I have hit 20,999 posts, am I a Senior Member yet?
