Old Feb 10, 2019 | 11:22 AM
ROB311952's Avatar
ROB311952
Smile Re: $2,230 To Replace O2 Sensors?
My check engine light kept coming on because the codes P0422 and P0432 (bank 1 and bank 2 cats performing under minimal efficiency). Stealthership wanted $7 grand to replace both sides! Cataclean didn't fix it. I replaced one rear O2 sensor with a Bosch (for ~$100 and something) but that didn't fix that side. Cats were not plugged or rattling, idle was so smooth I had to look at the tack to make sure it was running sometimes. Power was better than my first SRT-6. I could be running 30 mph and punch it and the rear end would break loose until the traction control caught it - so no power issues. Mileage was same as the first one also, 19 to 21 depending on how much foot I put into it. Voltage readings showed too much activity at the rear O2 sensors. I added a pair of mini-cats (Ebay https://www.ebay.com/itm/FOR-OFF-ROA...72.m2749.l2649) and voila - no more codes, pending codes, CEL/MIL Lights, and it successfully completed all 8 circuits needed to pass emissions inspection. Also, despite testing/playing and putting my foot into it more than usual, boosted my gas mileage to an all time high of 24 mpg! I know they say off road use, but unless you live in California or NY or another CARB state where you can't make any modifcation, it shouldn't be a problem as they actually boost efficiency.
