Hello,
I am from the other side of the world, a new member from Spain.
A friend give me her car, a Chysler Crossfire 3.2 218hp manual with 420.000 Km with a transmision problem (clutch, in my opinion).
I will repair it in my house, but first I come here to be advised about the previous checkings before open the clutch.
Of course, Iīve read this topic.
https://www.crossfireforum.org/forum...-04-coupe.html
I would like to explain the main problems of the car:
The main problem, car doesnīt move. You can pick one gear, and release the clutch pedal. It wonīt move, and It wonīt cut out.
So in my opinion, i think it is a clutch problem, but I donīt know if dual mass flywheel can be broken and not transmiting move. Should I check something more? (Hydraulics may be?)
Other problem, car trunk canīt be closed, I find some info about the closing mechanism in the car floor, under the trunk mat (may be dry and clean?)
The less important problem is that under the rain, the car roof gets wet. Front windshield, upside the windscreen is missing, could it be a reason?
Finally, I post a picture from the car carried by the crane.
Thank you!
