Thread: Supercharged??
Old Feb 17, 2019 | 01:47 PM
DualSportDad's Avatar
DualSportDad
Default Re: Supercharged??
Originally Posted by UrbanE
Engine
new hoses
transmission
drive shaft
Pumpkin
half shafts
when you pull these, best to redo the bearings
POWER steering hoses
fuse block is different
tranmission lines because of the intercooler
different location for secondary air pump with new wiring
THESE ALL HAVE TO COME FROM THE SAME CAR
ECU
TCU
BCM
skreem
key with fob
door lock cylinder
$650-$1000 on eBay
will need to get the ECU flashed to work with the deployed wing or find a fixed wing The ECU from the donar will not register the deployed wing
Thanks, from the sounds of it the guy might have all of this stuff still. Maybe even the whole car.
