Old Feb 26, 2019 | 07:35 PM
zip439's Avatar
zip439
Default Re: Second Autocross of the Season
I wouldn't use the adjustable bolts to decrease camber unless you have the K-macs and intend to dial in more camber at each race. I was wearing tires down badly on the inside while still having plenty of tread on the outside of my front wheels so I installed the febi eccentric bolts on the front end and thus reduced the negative camber. (search for: DIY eccentric bolt install) This worked well and my tires wore evenly for every day driving. However, up at the Dragon this past fall I went into the ditch and messed up my suspension. I did not give it any thought until I played back as to what happened other than going too damn fast for that turn, but my front end went off the pavement first. Classic understeer from my perspective. What I'm getting at is your car will handle better with the factory set up, vice using eccentric bolts to get better tire longevity. The K-macs make the adjustment a little easier, but you will need to adjust toe in as well if you mess with the camber for racing and then try to dial it back for less aggressive daily driving on the roadway.
I have a set of Bridgestone Portenza RE 11 on a separate set of rims which in the past I had put on the car for our fall Dragon get together, but this past year I stayed with the all season Michelins Pilot Sports AS3+. The Bridgestones had aged quit a bit so I was thinking to behave myself on the roads and the Michelins which have always given me good control would be just fine. My mistake!
