Hello Friends, I found a coolant leak on my SRT-6 in the area where the water pump is located. I can't track down the leak exactly, but I believe it may be a failed gasket as it appears the water pump part that spins and is attached to the serpentine belt is in reasonable order. I have 125k miles and figured I'm just going to replace the entire SRT-6 water pump at this time.
I found a lot of aftermarket water pumps using the above mentioned SRT-6 part number, and would like to ask if this listing is reasonable to use?
https://www.ebay.com/itm/New-Water-P...1/172433268997
My understanding is that many aftermarket SRT-6 water pumps need to be tapped for one of the bolt holes and that they also have a different alternator placement arm vs. N/A water pumps.
Any advice or confirmation on that aftermarket SRT-6 water pump?
