Thread: water pump
Old Mar 3, 2019 | 09:29 AM
onehundred80
Default Re: water pump
Originally Posted by AlbertFattal
Hello Friends, I found a coolant leak on my SRT-6 in the area where the water pump is located. I can't track down the leak exactly, but I believe it may be a failed gasket as it appears the water pump part that spins and is attached to the serpentine belt is in reasonable order. I have 125k miles and figured I'm just going to replace the entire SRT-6 water pump at this time.
I found a lot of aftermarket water pumps using the above mentioned SRT-6 part number, and would like to ask if this listing is reasonable to use? https://www.ebay.com/itm/New-Water-P...1/172433268997
My understanding is that many aftermarket SRT-6 water pumps need to be tapped for one of the bolt holes and that they also have a different alternator placement arm vs. N/A water pumps.
Any advice or confirmation on that aftermarket SRT-6 water pump?
The part number in the ad is correct, but the price seems too cheap, does that signify poor quality?
Let us know how it is when you get it.
