Thread: what is this??
Old Mar 3, 2019 | 09:49 AM
onehundred80
Default Re: what is this??
Originally Posted by amx1397
steve this system is to separate the water system (factory system goes through the radiator),( to lower IAT"s.. the tank, the heat exchanger and the motor with those valves closed the water in the heater never goes through the radiator ,,,it goes from the inter cooler pump to under the supercharger to the intercooler then to the heat exchanger then back to the intercooler pump remember on my car i had the killer chiller and my iat were 45 to 60 degrees most of the time yet my engine temp was 190. ,,you could have used a limited tank (as it only has one hose connection ) and saved about $100.00 jim
call me if you have any questions working on my newest V8 crossfire
If you use the NA tank you would need to fill the IC cooling circuit separately, easy if you have the BMW tank fitted, not so easy if you do not. Would that be a correct interpretation as I am not really familiar with the cooling circuit?
