Old Mar 9, 2019 | 03:19 PM
  #152 (permalink)
maggy55's Avatar
maggy55
Default Re: Let's discuss the key fob transponder chip(s)
This is the response I got when I questioned them about cloning ,
"There is no such things as cloning this type of transponder because it uses a rolling code and every time you turn key in the ignition the code will change so if you clone it then the other key will stop working next time you turn it in the ignition.The only way is by programming chip directly to the immobox "
