Re: changing headlight bulbs!!
If I recall, one side is easy to access and the other is a beyatch. Even worse in the SRT6 where you have to remove some pieces on the driver side for access. I had a real tough time aligning them correctly (first, second, third install they pointed down instead of out). Picked up a cheap stick mirror to see how the tabs aligned and try #4 was perfect. But yes, having small hands (good job for Trump) and patience helps.
