Thread: Empty gas tank
Old Mar 26, 2019 | 10:08 AM
onehundred80
Default Re: Empty gas tank
Originally Posted by moejoe
2005 coupe in garage for the winter. Started up fine every time. Strong odor? After 4 months gas tank that was full is now complety empty. Called 3 local Chrysler dealerships and all 3 said they no longer service crossfires. Any one else have this issue? Thanks, Maureen. Georgetown MA
Do you have anyone with access to the car who is larcenous by nature?
If it is a leak then there should be a stain on the floor beneath the leak.
If this is a failure of the rubber and caused by the ethanol in the fuel it would be the first time that I remember it happening here, the fuel hoses are lined with an ethanol-resistant material PTFE (Teflon) and are not nitrile rubber anymore. The OEM hose could have been replaced with the wrong hose material. The clamp may have cut through the hose.
