EdwardB
My mechanic has replaced some pulleys, a belt and bearings and I am now in search of shims.
We have a question as to much play should be between the pulley and the shaft to where it mounts. there's a fair bit of play that my mechanic is concerned about. Is there any way to just replace the shaft to where it mounts? Can anyone point me in the right direction? My car has been sitting for two weeks and i'm losing hope
the pulley should slide on ,sometimes u need to tap the pulley on to the shaft there should be no play sideways with pulley and shaft.
the distance between the pulley and the supercharger housing i am not sure because i set mine a little tight , but i think you can set it about .015 to 020 measured at three places all at once because the springs in it lets it move if you try to measure on only one side.
shaft replacement ,,new supercharger or take yours apart ,replace the rotors.
put your pulley on and ,,turn,,rotate the magnetic pulley (that black looking thing behind the pulley) if it turns and is about 0.10 to .030 clearance you should be good.
