EdwardB
My mechanic is most definitely not full of it. He's not trying to sell me on labor or parts, again I need to find the time to upload the most recent recording. He used a tool that did measure and isn't clueless.
Again, my pulley slides in and out of the shaft with NO resistance. This is on cold metal, not hot metal where you're supposed to use a towel to remove the pulley, he can do it with out the heat and put it on with out a mallet, that's how bad the shaft is when it comes to gripping the pulley
The SC pulley
should slide on with no resistance. It's not a press on pulley. None of us that I know of has had to use a mallet! If the shaft is clean and free of surface rust it will slide on like butter. I finger spread a drop of Jet Oil II on the shaft beforehand. Is it possible that your mechanic is thinking there's a problem that really isn't there?
