EdwardB
This was information that I got told by the phone call I took from I believe AMX, my mechanics question was if the pulley was supposed to be an easy slide on or was it supposed to be rough? I will upload the video early next morning to show you what hes talking about on the shaft being warped.
Can I get confirmation from another person if the pulley is supposed to be an easy slide on or not?
I have fitted several SC pulleys, and each one has slid on the shaft without any force, at ambient temperature, The old ones also slide off.
The only time you need anything heated, is if you are changing the pulley bearing. In this case you can use heat, to aid in the installation.
As far as a noise is concerned, is it coming from the gears perhaps, has he checked the oil in the front of the supercharger casing ?
