Old Apr 8, 2019 | 10:09 PM
cheetah500's Avatar
cheetah500
Default Re: Nothing but trouble
Common problem, once completed, you won't have this trouble again. check here:https://www.crossfireforum.org/forum...key_fix_v5.pdf
https://www.crossfireforum.org/forum...y-success.html
Yes I did see the sticky key fix. was reluctant at first, but took out switch housing and removed cam pin and spring, did not remove tumblers, everything good. Thanks to all...on to the next problem... drivers window only works a time or 2 after you pull the fuse and replace it.same fuse it is not blown... switch has been replaced, motor must work... a relay?
