Old Apr 10, 2019 | 12:10 PM
onehundred80
Default Re: Lost alignment after changing lower control arm?
Originally Posted by FrenchyAlex
I have only had the car for the past two years and did all the oil changes myself. From the Carfax report, previous ones were done by
local shops.
Interesting thought, but you would think there would be some oil stains on the arm, and there doesn't seem to be.
I have zero experience in how bushings age. When I looked at this one, I just figured this was normal after 15 years spent in a hot tropical climate, I wasn't exactly surprised.
What did surprise me though, is that the other bushing on that same arm looked quite good. Although they are not the same thickness/construction, I would have expected both to be worn out the same.
What will be interesting will be to drop the control arm on the passenger side and look at the rear bushing. If it is in a much better shape, then yes, the driver side bushing that I posted a picture of was either defective from the start, or sprayed with an agent it did not like.
What's funny is that after all this, I still have that cracking noise coming from the driver side suspension when turning the wheels all the way...
I do not think that playing around with these parts is too smart, even if you can get the steering to feel correct something may still be misaligned and cause excessive wear on the tires which may end up costing you more than a correct fix and alignment by experts.
