Old Apr 14, 2019 | 05:02 PM
  #230 (permalink)
Moore2575's Avatar
Moore2575
Default Re: How to take apart a key fob without destroying it!
Originally Posted by HazMatt
I've tried it numerous times and just gave up. Inspecting both Fob cases I can't seem to find anything different between the two. They are identical. I'm trying to put the old key in the new fob case. Apparently the slug that came with the case is not an identical match to the original key that came with the car. I did have the slug cut but it would not work in the car, I guess they didn't do a good job. Very frustrating.
mine was the same way , i could close the key then whhile it was closed barely push the top/side of key and it would stay closed. That was with having the original key not the new key that came with fob. Had the key cut that came with fob and no problems. Local lock shop cut the key while in the fob for $20
