Old Apr 14, 2019 | 10:38 PM
  #236 (permalink)
ala_xfire
Default Re: How to take apart a key fob without destroying it!
Originally Posted by Saul Klein
So, IF a Crossfire owner had ONE good Fob/key, and wanted to have a second "key" that works, COULD they take the metal key off the ONE they have, place/attach the good fob with transducer chip near the ignition switch "halo" , then have another metal key made by a good locksmith, and use the metal keys to start the car, with everything ok as normal ??
And if so, where is best place to "attach the good fob ?
Thanks,-Saul
Yes, you can remove the transponder chip and secure it out of sight very close to the key ring antenna.
BUT !
If you do this, make sure you don't then get any other fob with a chip close.
