Old Apr 17, 2019 | 10:54 AM
onehundred80
Default Re: Thread too large to be able to edit it
Originally Posted by IB Cheryl
There is a lot of confusion as to what problems/issues are being described. Our job is not to maintain and update threads for users. We do, however, fix the root cause so that the user can edit their thread themselves and the problem hopefully does not come up again in the future. Can you answer these questions below?
1) How are you editing the post, which button are you clicking to edit it? Is it the "edit" button on the bottom of each individual post?
Edit at the bottom of the post.
2) What device and what browser are you using?
FireFox on Windows 10
3) Can you take one section you are trying to edit from your original thread and copy and paste it into this thread as a post?
Engine SRTSyfi's do it yourself DCAI-1 PDF
SC pulley install-Code 3 shown-others the same. PDF
tighed1's Super cooler install PDF
Replace alternator/generator on SRT6 (NA similar)
NeedsWings SRT-6 Single Air Intake Install - PDF
SRT6 Inter Cooler pump always running method.
Oil catch can install For the SRT6
Install a Johnson IC Pump PDF
Supercharger Oil Change by 70GT6 PDF
Super Charger and Pulley Bearings PDF
SLK oil level sensor operation PDF
Secondary Air Pump repair PDF
Supercharger operating details and set up.
Super Charger pulley mods discussion.
Super Charger technical discussion.
Super Charger specs and load chart PDF from rcompartSyfi's do it yourself DCAI-1 PDF
