Re: LED tail lights
yup, jm, those are the bulbs i have in the car for the brake/tail function. i got the same info from them when i needed to insure the correct bulb for the application, and they are the folks that explained the fact that the built in resistor wasn't enough of a load for our system to eliminate the lamp out indicator. tfheir only solution was the resistor addition to the wiring of the socket. that is why i am hoping someone will be kind enough to share their wiring diagram for a setup thwt works with the addition of a resistor to the socket wiring.
steve
