Old Apr 19, 2019 | 12:14 PM
Doverhahn's Avatar
Doverhahn
Default Centre console question
OK, Upfront.
I did a lot of searching, but have not found what I am looking for.
As I have purchased a so called "Exklusive Paket" (looks like a carbon surface) which should replace the silver centre console parts, I ahve started the proces of removing.
- Gear shift **** off (Automatic)
- Radio removed (Went pretty easy, was a surpise :-) )
- 2 screws out
- pulled the centre console plate out.
Next stept is to remove the switch box for the centre console switches like seat heaters etc. (Hope you know what I mean):
According to the manula, there are "just" 2 latches which need to be openened to remove the whole unit.
Been looking at it for a couple of minutes but WTF, where are those 2 latches ???
I have seen 6 or 8 smaller clips, which you can open and you have an opportunity to take a first part out (2 outer switches), but not the full unit.
Anyone has a picture (or more) about how to take off this module?
Thank you
Alwin
BTW:
I have putt everything together again as I want to go for a longer drive tomorrow. Again without the carbon look centre console. :-(
