Thread: Repair codes
Old Aug 22, 2006 | 12:17 PM
C_Plunkett's Avatar
C_Plunkett
Default Re: Repair codes
The FSS (the wrench icons in the odometer) only indicates when routine service is required. It typically shows the number of miles remaining until the next oil change, but if your car has been sitting a lot, it will show the number of days instead. If it displays the clock and a number, the number is the number of days remaining until you need to get your oil changed. If it is a negative number, then you are that many days over.
