Old Apr 22, 2019 | 05:58 PM
  #81 (permalink)
BlakeSwain's Avatar
BlakeSwain
Default Re: Double Din Dash Kit - Teaser - Far from done!
Update:
I finally cut/installed the new panes of glass in my printing enclosure and am happy to announce that I'm officially printing in ABS plastic (sorry for the the messy window glazing job... but was more than ready to start printing)! I have done a total of two prints... The first print (left side HVAC/D-Din) had to be modified yet again for better fitment (some of the rear pegs weren't fitting/lining-up as clean as I wanted. The first print will have to be reprinted due to me cutting and shaping for the proper fitment (plus I accidentally split part of the bezel driver's temperature control **** cutout area when cutting and trimming the rear layer). I made a few design changes and printed the right side with thicker edges and have increased the peg base thickness to insure its durability. As soon as I get off work, I will be test fitting the second print. I have customized this to fit my particular stereo (Xtrons Octacore 4gn Ram 32gb Rom Android Stereo). I did not purchase a double din cage, and have already began the design of the cage that will correspond to the factory single din sleeve. I cut the bottom of the OEM sleeve out, but left about 1/8-1/4 inch on the sides. My plan is to make 1/2 a cage and use the top single din sleeve with a printed lower half cage that will have two screw or rivets to the OEM sleeve and have attachments points on the rear layer of the bezel. The actual OEM single din sleeve has two recessed slots on both sides that I would like to use for the connection points. This will allow me to always return/re-install the OEM bezel and radio (if ever needed/wanted to).
If all goes accordingly, I will be reprinting the left side and will be moving on to the ashtray switch relocation being printed in ABS and will have to finish designing the mount brackets. My plan is to have this setup as 3 separate prints. The two halves of the HVAC/Double din bezel & the lower ashtray/switch relocation. I decided to combine both the top layer and rear layer as one. The ABS is black, and the easier to print PLA plastic is white. The black print does appear to have a bow on the bottom, but that is the nature of it (ABS tends to warp with very small temperature variations in the printing stage, that is why it requires being printed within an enclosure).
The fusion between the layers with all the mounting clips have printed really well! I can easily attached both with abs epoxy, but after thinking more on it.... may hold off until I decide whether to sand/prime first then attach before painting (help maintain the center spine) or attach and complete the sand/paint after assembly... trial and error will tell. I'm still on the fence of wrapping the silver trim in upholstery leather/vinyl. I can print in different colored plastic, but ABS greatly deteriorates with UV rays and would have to be clear coated. Trying to finish the official build, and then choose the finish.
I hate that there aren't any steering wheel control buttons... and rather than a load more work/cost of installing a Mercedes Benz steering wheel I am going with a different options. There were a few options that allowed me to add wireless controls that were attached to the steering wheel with double sided tape, but just felt these seemed cheap and not having a perfectly flat area on the wheel would end up looking quite awkward to me. I have always liked the idrive style multimedia controllers in the BMWs and Benzs.... but didn't want the extensive task of modifying one just for simple stereo options. I finally found a wireless center console remote control. The one in particular has added phone/Bluetooth buttons that all are customized in the steering wheel control options of the head unit. I currently have a simple Bluetooth remote that I have attached just below the shiftier, but it shuts down (conserves battery) so often I constantly have to hit a button just to reconnect and then hit the button again just to change the volume, track, etc. The last photo shows the remote I have ordered and may be a bit to get here since I had to order from a Chinese seller (no-one offered this within the U.S.). This states specifically it is intended to work on Android stereo head unit.... but I believe as long as your aftermarket stereo has 3-5 workings volts for the steering wheel control lines for the majority of aftermarket stereo head units. Will NOT work on our OEM stereos, the factory head units do NOT have steering wheel controls (I know someone will probably read and ask. Planned on installing just below the shiftier as my current Bluetooth one is.... This may be just a tad bigger than the bezel, so I'm already planning to design a base that will help it to blend right in with the bezel to keep the slim-lined style!
Enjoy!
Example: Shows side recessed channel that I will use to attach the customized lower half of my double-din cage.
New remote control for Android Double Din unit.
