Thread: Lugs length
Old Apr 23, 2019 | 10:09 AM
onehundred80
Default Re: Lugs length
Originally Posted by austinbarrylee
I have aftermarket Mandrus with 20mm spacers. Can please someone tell me the proper size lug/studs so I don’t damage the emergency brake. Thanks.
If the seat shape (ball seat) is the same as the OEM wheels and the bolts stick out the inside of the wheel the same amount as on the OEM wheels, you would need 40 (OEM size)+ 20 = 60mm bolts. Any difference from this OEM setup would have to be calculated.
The bolts need to stick out from the spacer the same as the OEM bolts in the OEM wheel.
