Fla_Xfire_SRT
I got it , thanks. I had to remove the 4 seat bolts and lift the seat to get under it. The keys ended up just above the seat tracks which luckily didnt get into the teeth of the track while it was moving. Usually the seat doesn't move, some days it does, others it doesn't..today was lucky. Now to go vacuum under the seat and remount it....Thanks again.
Had same issue with the seat moving only once in a while. It ended up being the seat relay under dash. I re-soldered the relay, but that did not help. I did not have a new relay (had to order) and did not want to put everything back together and then take apart later.
Looking at the wiring diagrams I realized the I can use regular Bosch relay (which I had plenty) - the only downside is - seat will not move with the door open and key OFF, only with ignition switch in ACC/RUN. I just plugged the relay in and decided not to buy original relay.
