Old May 23, 2019 | 08:49 AM
zip439's Avatar
zip439
Default Re: Electrical issues!!!
If you pull the BCM out of your car the part number is easily seen on the case of the BCM. Replace it with the same part number. I'm skeptical of electrical parts on ebay. If the part number matches at redline I think you will get a good part.
If you have damage from rodents the test of fuse 19 as I outlined in the third post will go a long way on clarifying your problem.
