zip439
If you pull the BCM out of your car the part number is easily seen on the case of the BCM. Replace it with the same part number. I'm skeptical of electrical parts on ebay. If the part number matches at redline I think you will get a good part.
If you have damage from rodents the test of fuse 19 as I outlined in the third post will go a long way on clarifying your problem.
Ok I’m going to check the voltage in fuse 19 and can I pull the bcm carefully on my own or should a repair shop do it? Also the seller has a free return policy if the part is not operable or does not match my vehicle so that’s a plus for me
