Old May 28, 2019 | 05:32 PM
amx1397
Default Re: V8, keep up with my mods
Originally Posted by JEFASOLD
One other mod I've done is to use a eurocharged HE, which is much wider, then opened up the lower grills by drilling and grinding out a couple more squares on each side, which lowered my temps a few degrees, definitely worth the work.
my exhaust is 2.5 off engine to the Y then 3" to a 3"resonator/open muffler inline then 3" into the srt6 muffler (((opened the muffler to 3" inlet and two 2- 2 1/2 outlets))
lowered the radiator support 3" and moved froward 3" modded fan from a mercedes car, set up on stock temp setings, the fan has never gone full speed, we did cut down the fan to fit into the crossfire. Needswings supercooler and small water tank in place of air pump, located high as the engine, fuel pump from mercedes with a adjustable regulator set at 65 psi,with vac hose to maintain 65 psi through out boost range.
I have a sound bite of the exhaust as soon as i can get it to post, tried earlier with no luck.
