Drink Spill In Gear Shifter
Hey guys, i recently just spilled coffee into my gear shifter box. (That damn cup claw sucks!) My issue is that now, my xFire will not shift up or down, and does not display the gear PRND1234 gears in the gauge cluster. It does not display any gears, and driving it like this makes the rpm very high, cannot go up to speeds higher than 45mph. Also it has trouble going from frive to park when the brake is pressed, so i keep the multi tool handy to manually allow it.
With a little research i found out it could be this { Chrysler CrossfireTiptronic floor shifter } , and also now the vehicle displays an engine code of P0705. Im considering buying a replacement and hoping that fixes the issue, but before i do, i would like to make an attempt at cleaning the assembly before buying a replacement. Does anyone have any suggestions also any tutorials on how to remove the assembly and so forth? That would be grea thank you so much in advance! You guys have solved EVERY issue that i have come across with my XFIRE, so any advice is welcome, and much appreciated.
