Thread: 2004 crossfire
Old Jun 4, 2019 | 04:03 PM
onehundred80
Default Re: 2004 crossfire
Originally Posted by AlanSalinas
Whenever im driving ,out of nowhere the right turn signal pops out on the dash board and stays stuck with out me moving the turn signals switch. Then out of nowhere goes away and pops out again. Sometimes this happens whenever the car is off as well and it drains the battery out.
I just had the same thing happen to me, I had the bank of switches with the Emergency flasher in it out. The centre module was not in properly and the Emergency button was not pressed in, it was not lit though. The module that has the Emergency flasher in is a separate module it plugs into the main switch panel. It was at an angle and only one of the turn signals was flashing, I straightened it and pushed it in fully and the red triangle lit and the other turn signal signal started flashing.
