2004 crossfire
Old Jun 1, 2019 | 07:09 PM
AlanSalinas's Avatar
Default 2004 crossfire
Hi, I am in desperate need of some help! The right turn signal of my 2004 crossfire keeps on getting stuck. The only way i can take it off is by double clicking the lock/unlock button on my key remote. What could be the problem/what can i do?
Thanks!
- Alan
Old Jun 2, 2019 | 10:13 AM
Speedy4x4's Avatar
Default Re: 2004 crossfire
The lever is not sticking, but the bulb keeps flashing ???
Old Jun 2, 2019 | 11:08 AM
Thanks!
- Alan
Pull the fuse for the security pump in the trunk, it might be caused by the pump operating the bulb as when the car is locked or unlocked. A sheer guess but you never know.
Old Jun 4, 2019 | 02:48 PM
Whenever im driving ,out of nowhere the right turn signal pops out on the dash board and stays stuck with out me moving the turn signals switch. Then out of nowhere goes away and pops out again. Sometimes this happens whenever the car is off as well and it drains the battery out.
Old Jun 4, 2019 | 04:03 PM
I just had the same thing happen to me, I had the bank of switches with the Emergency flasher in it out. The centre module was not in properly and the Emergency button was not pressed in, it was not lit though. The module that has the Emergency flasher in is a separate module it plugs into the main switch panel. It was at an angle and only one of the turn signals was flashing, I straightened it and pushed it in fully and the red triangle lit and the other turn signal signal started flashing.
mthtulsa
Aug 3, 2015 06:14 PM
Rob M
Jul 12, 2004 11:00 PM
Rob M
Jun 9, 2004 11:48 AM
crossfiretech
Mar 5, 2004 07:43 PM
texex91
Feb 26, 2004 09:28 AM
