Groucho
Thanks guys,
But the first problem is that I
cannot check the oil level in the car. I get a blank screen - No Hi and no Low. Could the oil level sensor be bad in the car and is not responding to the inputs?
Thanks dedwards I will try the reset again. I did disconnect the battery for 10 minutes and tried again last week "but still a clock a wench and -730" Like a slot machine..
I just checked the dip stick and it is almost to the top notch
Top notch is good, so if it is not too high or too low why would you expect a warning?
