Brake rotor not seating
Putting new pads, rotors and brake lines on the black SRT. when I install the small retainer bolt on the left rear rotor the rotor lifts away from the hub on the opposite side. I have pulled the rotor off twice to check for debris and all is clean. Shall I assume the wheel will pull it flat or should I suspect the rotor?
