Old Jun 8, 2019 | 10:16 PM
pizzaguy
Default Re: 2005 convertible top not operating
Originally Posted by scottdj
When i manually unlatch the top, the drivers/passenger side windows automatically go down every time - so i don't think it's the switch in the frame above the passenger side window.
Ok, you have this one wrong. The latch switch in the windshield frame is what tells the TCM to tell the BCM to lower the windows.
The top open switch above the passenger's head is wired in series with the divider switch. When the divider is up and properly seated the divider switch is closed; and when the top is pushed away from the frame, and pressure is relaxed on the arm of that switch, it closes.
With the two in series, they apply a ground to the pin on the TCM, telling the system that the pump can be operated.
