Old Jun 15, 2019 | 04:58 PM
onehundred80
Default Re: Coolant leak only after the warmed up
Originally Posted by cj89821@yahoo.com
These 2 specifically
The bolts were not discontinued, as they were not made especially for the car. They are available somewhere, you could use the same bolt but an Allen head instead. You should get a special plated type to avoid the steel corroding the aluminum alloy as it is in an exposed place for moisture and salt if driven in those conditions.
