Old Jun 19, 2019 | 12:31 PM
onehundred80
Default Re: My 2004 Crossfire...
Originally Posted by lovecross
Wow! Welcome back. Brake fluid replace & bleed, Thermostat w/ coolant change, rear end gear oil, was gas tank full & w/ some stabilizer? (prevents rust), Drain & refill, replace fuel filter? Transmission fluid? TPMS sensors likely kaput.
Good luck!
The gas tank is aluminum, no rust. Sixteen gallons of gas when full is a lot of gas to get rid of. Rear end oil is better than mine so no need to replace. Fuel filter has seen no action so it should be OK.
New tires, the ones you had have deteriorated a lot, and are not safe at any speed to quote Ralph Nader.
