Re: ARES 70921 Manual Brake Fluid Pressure Bleeder
Really wow! Now I know how to use it. Thanks for the instructions.
[/QUOTE=WD40;925212]Right. I used to have one just like it except without the "bicycle pump" on the side. Instead it had a pump handle on top of it. It worked for 4 or 5 years then for no reason it stopped drawing a vacuum and I threw it away.
With the Mightyvac you do all the work at the caliper(s) as it draws a vacuum through the bleed nipples. With the pressure-bleeder at the top of my post it pressurizes the entire system and you simply walk around opening the bleed nipples so the brake fluid can come out.[/QUOTE]
