Old Jun 26, 2019 | 01:29 PM
RL67037's Avatar
RL67037
Default Re: 2005 Won’t Start
Not certain, but since the wire color changes, it must be a wiring connector.
And lo and behold, I found it !
And it's located inside the box by the battery :
ala_xfire - I've seen you post a few diagrams over the years pertaining to the pulse module. From a 2014 post and from this post, I am learning that the C106 connector is in the same box as the RCM but the actual Pulse Module is in the driver's side fuse box under the fuses - is that correct? If so, how do I go about getting the fuse tray out of the driver's side box? Are there any "gotchas" I have to be aware of?
Thanks!!
