Jim Holian
Anyone - Is replacing the ignition switch with one for a 07 or 08 feasible? What all is involved in replacing the switch. I assume a new switch will require a new set of keys, possibly a new SKREEM, and so on. This could get pretty involved, and pricey, unless a new switch can be re-tumbled for our existing keys. Boy, one little sticky, hard to turn switch can really mess up a good car! Comments?
Jim
Replacing the switch is fairly easy and doesn't affect the tumbler, keys or SKREEM.
First, remove the cylinder lock housing as you would for the Sticky Key Fix.
The actual switch attaches on the back of the cylinder lock housing with 3 screws.
However, if you are replacing the cylinder lock housing AND the switch, just re-use your existing tumbler and Bob's your uncle (as my Aussie bride would say).
https://www.ebay.com/sch/i.html?_nkw...gnition+switch
