Old Jul 1, 2019 | 10:06 AM
  #1087 (permalink)
Malcolmomar's Avatar
Malcolmomar
Default Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
That doesn't not surprise me, I think it is German over engineering designed to prevent the locking rod being forced somehow, though I cannot imagine how... Your comment implies that if you replaced the mechanism with a late Mercedes part all problems would go away., though I suspect just removing the spring loaded pin gives long term releiability. do you happen to know if the barrel and key are showing issues whether the dominant cause is wear in the barrel or wear ion the key? M
