Old Jul 8, 2019 | 01:11 PM
onehundred80
Default Re: Replacement key fob
Originally Posted by Rapp47
Recently purchased a 2005 Chrysler Crossfire and the owner only had one key fob which is in very bad condition. I purchased a key fob on eBay and took it to a TrueValue hardware store and they cut the blade but it will not unlock my door. Is there a chip or a programming necessary for the blade to work? From what I'm hearing I have to purchase a $581 key fob through Chrysler for it to work. Help!!
The key is the easiest part to copy.
The fob needs a programmed chip inside the fob to disable the security system and allow the car to start.
To unlock/lock the doors the transmitter in the fob has to be programmed to unlock the doors.
As your key cannot do the even the basic task you have a long way to go.
Your new fob is it just a bare case? I suspect it is.
The current cost cost of a new working fob is $659.95 from NeedsWings.
