Old Jul 13, 2019 | 04:29 PM
earlj's Avatar
earlj
Default Re: Roadster Antenna base gasket ???
Originally Posted by awilson40
Anyone know where I can get the gasket between the antenna base and the fender ?
I see no part number listing for just the gasket.
Thanks
I you type in antenna gaskets on the internet you will get a lot of hits. I purchased a gasket for a VW antenna and it fits great. No glue required and you do not have to remove the antenna. Tape off area surrounding the antenna. Then using a small screwdriver, carefully remove as much of the old gasket as possible. Slide new gasket down antenna and fit in place. You may have to remove some of the rubber on the inner portion of the antenna gasket. My gasket fits perfectly
