Roadster Antenna base gasket ???
Old May 24, 2017 | 10:26 PM
Kurtp13's Avatar
Default Re: Roadster Antenna base gasket ???
You're right not typical. But my sister can do anything. And when my daughter needed car work done we did it together. There's no reason a woman can't do the work. Good for her.
Old May 25, 2017 | 06:53 AM
One of the ladies in the East Coast FLorida Crossfires Facebook Page just changed her's today.
All by herself. Pretty cool when a BLONDE LADY can do it herself!
(You can meet Diana yourself this fall at the Dragon. )
She's the really attractive lady with the winning smile, can't miss her
Old May 25, 2017 | 07:46 AM
djohn14296's Avatar
Thumbs up Re: Roadster Antenna base gasket ???
Yea, get this :
The antenna is a bit shorter than OEM, but it screws right on and to me looks even better.
I second that, to me looks better.
Old Jul 12, 2019 | 03:53 PM
XFireCrazy's Avatar
I just ordered this full antenna assembly for about $13. Should be super easy to replace the whole thing from what I just saw in my trunk.
https://www.ebay.com/itm/123761687923
Old Jul 12, 2019 | 05:10 PM
you are gonna find out the the OEM one has 2 wire connections whereas that one has just the single.
Old Jul 13, 2019 | 04:29 PM
earlj's Avatar
Originally Posted by awilson40
Anyone know where I can get the gasket between the antenna base and the fender ?
I see no part number listing for just the gasket.
Thanks
I you type in antenna gaskets on the internet you will get a lot of hits. I purchased a gasket for a VW antenna and it fits great. No glue required and you do not have to remove the antenna. Tape off area surrounding the antenna. Then using a small screwdriver, carefully remove as much of the old gasket as possible. Slide new gasket down antenna and fit in place. You may have to remove some of the rubber on the inner portion of the antenna gasket. My gasket fits perfectly
Old Jul 13, 2019 | 04:41 PM
earlj's Avatar
Not true. Go on the internet and check the antenna gaskets for a VW. I installed the gasket without removing the antenna an it looks like New and no glue was required to keep it in place. Tape off area around antenna, then use a small screwdriver to chip out as much of the old gasket as possible. Slide the new gasket down antenna and fit it in place. You may have to remove some of the rubber on the inner part of the gasket to get a tight fit
4drturbo
Jan 3, 2019 02:46 PM
Adrian_X
Nov 9, 2017 08:49 AM
Indelibility
Aug 27, 2015 10:21 PM
Boresite
Aug 9, 2015 10:33 AM
MI1XFIRE
Aug 2, 2015 11:05 AM
