Re: electrical problem
I don't 'do' part numbers. I called NAPA and told them I had a 2007 Crossfire non-SRT, the guy told ME I had a "Valeo" (which I did).
The replacement fit, but the B+ terminal on the back had odd-shaped plastic around it, the lug would not fit. I cut the plastic away and was fine.
Three months later, the replacement failed. I ordered a warranty replacement thru NAPA. Replacement fit perfectly.
With the Valeo's you get what you get. As to fitting a Bosch, I believe it will fit, but am not sure. If you managed to wrestle the alternator off the car yourself, I'd say you will be fine with what ever replacement you get. But I'd try to order the same as what came off the car.
