Old Jul 17, 2019 | 10:37 PM
onehundred80
Default Re: Roadster Trunk Light operation vs Coupe
Originally Posted by Johnny Versatile
I don't think it is that simple. It is not just a matter of tapping in some where bit's the right somewhere. I had the map light switch apart today as I put in LED's. There is a 4 wire feed to the switch. I suspect this switch will carry a steady positive feed, as well as a feed for the slider switch, and the passenger door switch, as well as a ground. The wire I need to tap into has to be the right one or the "new" lights will not activate properly. They have to get the feed from all sources, each door and map light switch, at the correct time for it to work properly. I don't want to start poking at wiring with a "let's try this" take on things. Does anyone know for sure what will work? There are these "computers" that run things which concern me.
One wire feeds the bulb when you open a door and that is the one you want.
The Service Manual will have the circuit diagram and tell you the colour, quite simple.
